transmission fluid problems
Old Jun 10, 2009 | 01:04 PM
giaco43's Avatar
giaco43
Default transmission fluid problems
I seem to have a proplem with my 66 coupes auto transmission. It works fine, but if I try to fill the trans to the mark on the stick it pukes about a quart out of the vent pipe, plus the fluid looks foamy after running. when the car is not running the fluid level is right on the stick. Am I missing something? anyone have any ideas. Thx Mark
Old Jun 10, 2009 | 01:11 PM
rmodel65's Avatar
rmodel65
Yukon Cornelius
the car has to be running to check the fluid level, you should be using type F transmission fluid
Old Jun 11, 2009 | 01:10 AM
giaco43's Avatar
giaco43
thx, I get it that the fluid is suppose to be checked while running, it says that on the stick, the problem I need help with is when i fill it to the full level it leaks out the breather when i shut the engine off. any other suggestions? Mark
Pyrate Dave
Sep 10, 2015 07:30 PM
IronRaptor
Sep 9, 2015 08:10 AM
vintageaion
Sep 8, 2015 10:45 AM
5.0 kevo
Sep 3, 2015 06:24 PM
