Turn signal switch
Old Jun 25, 2009 | 01:29 AM
p25486's Avatar
p25486
Default Turn signal switch
Hi, is there some trick to getting the turn signal switch mechanism out of the steering column? I remove the screws I see on the front (with the steering wheel removed). It appears loose, but won't come out. What am I doing wrong?
Thanks,
John
Old Jun 25, 2009 | 02:26 AM
68MustangCoupe's Avatar
68MustangCoupe
Thanks,
John
How I got mine out was I put a flathead under it and pried it out... During it Tons of sparks happened then I unpugged the battery... BUT I would not recommend doing that as there's a thin metal thing under that is electrified somehow... BUT.. thinking about it now, probably screw the three bolts back in and leave them out abit to stick a crowbar under them and pry them out *Maybe put a washer under them for more surface area for the crowbar to touch* BUT... I think there is an actual tool called a Steeringwheel PULLER that you can buy at like a autoparts store... Hope this helps any
*Forgot to add. Don't do the screwdriver thing because I messed up the edges of the thin metal thing doing it that way*
Old Jun 25, 2009 | 06:35 AM
2+2GT's Avatar
2+2GT
Yes, always disconnect the battery first.
Have you disconnected the wiring and removed the pin block from the wires?
Old Jun 25, 2009 | 11:09 PM
Carlos Pineiro's Avatar
Carlos Pineiro
Also, you can get a pin connector/extractor tool and it's quick and painless to change that switch. You can get one at Radio Shack for $4-$5.
If you just want to change the cam (because the signal doesn't cancel), you don't need to remove the switch.
CP
Old Jun 26, 2009 | 12:50 AM
p25486's Avatar
p25486
Default 73 coupe by the way
Sorry, I forgot what year I had.
Actually, the switch isn't making contact, so no blinky light unless I pull on the turn signal handle. Not sure if just replacing the cam will fix this problem, as someone pushed the car recently, and used the turn signal as a hand hold, result, the handle broke forward a little and now the signal is intermittent at best. Hazards work, so it must be the switch.
Old Jun 26, 2009 | 02:00 AM
4reboy's Avatar
4reboy
I just had the steering wheel off the 71 today (to replace the ignition), if I didn't put it back on I would go out and take a look for you! the pictures I took don't show me much good luck
EDIT: well maybe I can help a little, this article is for a 65 but the switches should be similar, so maybe it will give you some ideas!
http://www.mustangmonthly.com/techar...als/index.html
jma2
Jul 10, 2023 01:00 AM
9550
Oct 26, 2015 05:01 PM
Meystang
Sep 25, 2015 04:05 PM
TfcCDR
Sep 14, 2015 12:08 PM
vintageaion
Sep 8, 2015 10:45 AM
