How do I remove cap nuts - heater core cable
Old Sep 13, 2009 | 12:38 PM
GibMax's Avatar
GibMax
Default How do I remove cap nuts - heater core cable
I'm removing the heater core in my 66 Mustang because the old one leaks.
I'm following the instructions on this web page:
http://www.mustangmonthly.com/howto/5769/index.html
But I get to the part where I have to remove the cap nuts off of the cables:
http://www.mustangmonthly.com/howto/5769/photo_12.html
I don't know how to do this. Do they screw off or pry off?
Any hints are encouraged since I'm a beginner.
Old Sep 13, 2009 | 12:46 PM
Canary94GT's Avatar
Canary94GT
That picture is horrible. I really can't see what he is pointing to.
However, cap nuts are supposed to be these: and can be removed with a box wrench or socket.
But they might be talking about something else because I can't see very well in that picture.
Have you started disassembly or are you just looking over the instructions before you begin?
Old Sep 13, 2009 | 01:42 PM
GibMax's Avatar
GibMax
I've got one cap nut off and I just spent an hour trying everything I can to get the other one off including: screwing, prying, pulling, pushing. My next step may be a hack saw. But I'm not sure if I can find a replacement cap nut.
Old Sep 13, 2009 | 01:57 PM
GibMax's Avatar
GibMax
Default How do I remove cap nuts - heater core cable - Done
Done. The hack saw worked. Don't know how I'm going to put that back together.
Old Sep 13, 2009 | 02:49 PM
tx65coupe's Avatar
tx65coupe
The cap nuts that hold the cables in place on my 65 are just pressed on. They look like little hats. I use pliers or kneedle nose pliers to get them off and on.
Old Sep 13, 2009 | 04:08 PM
4reboy's Avatar
4reboy
+1 on the needle nose pliers... you used a hack saw? does this mean you made the rod for the flap shorter? that doesn't sound good to me.
Old Sep 13, 2009 | 04:32 PM
tx65coupe's Avatar
tx65coupe
I think one time I had to hold the cap with some pliers and actually take a wrench and used it like a little hammer against the pliers and tapped it off.
Hopefully, you didn't cut the rod, then it will be too short like 4reboy said.
Old Sep 13, 2009 | 06:49 PM
2+2GT's Avatar
2+2GT
They push on. They pull off. A little twisting helps.
Old Sep 29, 2009 | 01:47 PM
GibMax's Avatar
GibMax
Default Cap Nuts - easy to put back on
Yes, okay. I was able to push the cap nuts right back on with the help of a pair of needle nose pliers.
A few problems - the cheap cardboard heater ducts broke. Used some duct tape - not the best solution.
One of the cables is real hard to get to move back and forth. Manually pushed and pulled it. Must just be old.
Old Sep 30, 2009 | 06:40 AM
tx65coupe's Avatar
tx65coupe
Are you talking about the plenum for the defroster etc. A plastic reproduction is availble. and its inexpensive. The defroster ducts are also not pricey either.
http://www.mustangsunlimited.com/ite...asp?T1=HPA1+01
http://www.mustangsunlimited.com/ite...asp?T1=DDH2+01
http://www.mustangsunlimited.com/ite...asp?T1=DDH1+01
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
Dathan
Oct 5, 2015 05:52 AM
