crown vic disc brake swap on 66 mustang
I was wondering if i could put the crown vic disc brakes on my 1966 mustang i got 5 lug axles i saw somewhere that you needed a spacer
but will brakes fit and work good? what all do i need to take off of the vic?
is there any specific year range to look for or are all pretty much good?
thanks alot i hope to get them tommrow so hopefully ill get some post today
thanks again
thanks again
Yeh..... the brackets are thick is where the spacer goes. "Moser" has a bearing that seals with an "O" ring that works without the need for a spacer (its like built onto the bearing). Be aware that some "Crown Vics" will fit and some not. The years I don't know. Also the caliper orentiation will vary as well as the E-brake may give you some trouble. Make sure your homework first.
the mid 90s crown vics are what you need to look for
the police cars are the better setup with slotted rotors and different pistons in the caliper
as for making them work they are a bolt on on 8inch rear with a shim which you can find on ebay
How come nobody seems to put OEM type 65-66 disc brakes on when upgrading from 4 wheel drum?
Sure the bolt ons are simple, but be prepared to pull out the green. It seems that they range from $600 to over a $1000. I have changed 3 of my cars over to Explorer's or Crown Vic's for less than $200 for all three, and will be doing a 4th by spring (freebie set). To answer your original post, yes, but then again, do your research before you start.
Most people upgrading from 4 to 5 bolt are also converting to V8. I figure they are reading a lotta magazines in preparation, and said magazines, hoping to curry favor with their sponsors, recommend super-zoomy 14" slotted cross-drilled disc brakes with 12 piston calipers. Of course, for street driving such brakes are a waste of money, but if you are racing, or want to impress people with how much money you spent at cruise night, very useful.
not understanding
ok guys i was out at the wrecking yards today
i found a bunch of 92 and 94 crown vics with the rear discs
may sound stupid but im not sure what all im needing of it
obviously the calipers rotors but what else anyone have a pic of what i need or something i really wanna get them and for ten dollars a piece i think its a good idea
please help
thanks
please help
thanks
ok this is the kit you need to adapt, all the kit contains is the stuff to bolt on and shim the axles if you look around on yahoo google etc you can find the dimensions maybe get a machine shop to make some cheaper??
as for the parts take everything from the rear on each brake side, bracket calipers all bolts lines hoses etc if its hooked to the brakes take it with you
I made the change on my 66 using 93 Crown Vic calipers and rotors. Bolts up fine but be aware that you need to change the distribution valve as well or you will do doughnuts the first time you throw out the anchor. I also have an issue with the front honeycomb wheels not clearing the calipers. My buddy used a grinding wheel on them to clear but I am not happy with that. I am going to look for a smaller caliper that will bolt on and clear those wheels. Standard steel wheels are not a problem
