Tires...
The TA has been redesigned several times since they started making them. The manufacturer also said that within the last few years they have done other improvements to them.
Anyway, If you don't like them, then you don't like them.
I never said they were the best tire ever made, but you seem to think they are the worst. They are far from that. I have had some really lousy tires before.
I'm curious what everyone else is running. There haven't been many posts about the other tires.
No, they're not the worst tires out there, but they're not much better in my experience. They do have Michelin/BFG quality control, which means they're almost always defect-free, but that doesn't mean the tread design/compound is good. They sell because they've been around forever and look good, not because they perform well.
They probably work ok on your F150 because the pickup has softer (relative to the vehicle weight) springs and a larger contact patch. An automatic transmission also helps. The larger pickup sizes may also have additional sidewall and tread belts for more stability. Still, put a set of H-rated Falkens on the pickup and it'll be a different creature.
This tire grips well, behaves great in any weather and lasts! My father put over 120k on a set on his Exploder before replacing. They tend to have slightly more road noise on the highway due to the harder rubber compounds but the damn things are simply great everyday truck tires.
Great tire! I run the 255/70 16s on our 03 Exploder Sport (not the damn Trac crap) and they are great. I've made 7 or 8 trips up to Halifax, NS Canada from NJ over the past 2 years fully loaded with parts and a few empty trips back to Jersey. Trips are roughly 1000 to 1100 miles each way through heat, cold, heavy rains and deep snow. A bit of off roading/back woods in 3 to 4 feet of snow to go winter camping back in Jan (chilly @ -32), etc.
There have been a couple redesigns since they were originally introduced, but that was decades ago. The G-wedge sidwewall reinforcement appears to be new, but the tread design and compounts are still the same. Even the sidewall reinforcement can't help that much; they're still designed to have large, round, flexible sidewalls. Anything like that is going to fold over at high G's.
I'd look at BFG Traction T/A's, if they're still available. Very stiff sidewall for solid cornering, directional tread for good water traction, and 60k mi warranty. They won't be as quiet as michelins, but I doubt you'd notice in the Mustang.
If you can stand going to a Japanese tire (keep in mind, Michelin/BFG is French), Falken Ziex ZE512's are a good sporty all-season tire and very affordable. Yokohama also has some good tires in their lineup.
