voltage regulator
Old Nov 6, 2009 | 10:26 AM
tobias61's Avatar
tobias61
Default voltage regulator
Hello, i ordered a voltage regulator for my ford mustang 1966 without a/c and they delivered me a c5af-10316-a. In my car is currently installed a c5tf-10316-a. Some internet sites say that the c5af is for a early 1965 car and that the c5tf is for a 1965-1967 with a/c. But other sites say something different, like that the c5af is the correct one for my car. And other sites say i need the c5af-10316-b. Who has expierence with voltage regulator. Are they interchangeable? which one do i really need?
Thanks.
Old Nov 6, 2009 | 11:23 AM
MetalEd's Avatar
MetalEd
I don't know about the parts numbers. The AC part doesn't bother me, it's the year. An early 65 would be a generator with different wiring. You could always get a modern solid state regulator (transistor/computer chip) that would be more reliable than the mechanical one. These should be available from any autoparts store.
At the very least I would call around to some Mustang ONLY Suppliers and see what they would offer for your car, then use it or return it based on the results.
Old Nov 6, 2009 | 11:54 AM
2+2GT's Avatar
2+2GT
Thanks.
OK, the easy way to tell is the 3rd digit. Generally, a C5DF-10316-A would be originally engineered for a Falcon (D), and would be light duty. A C5AF-10316-A would be for a full-size Ford (A), and would be a higher service rating. Last, a C5TF-10316-A would be a a truck item, and would be seen with air conditioning, performance engine, etc. Of course, if you are talking about reproductions, they are all internally identical heavy-duty units, only the markings and case color change.
Old Nov 6, 2009 | 01:33 PM
tobias61's Avatar
tobias61
When i bought my car a voltage regulator with p/n c5tf-10316-a was installed (and stilll is). So when i instal one with p/n: c5af-10316-a, i can't blow something up? It will work normal?
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
TfcCDR
Sep 14, 2015 12:08 PM
cbird1177711
Sep 3, 2015 08:43 PM
cbird1177711
Sep 2, 2015 08:51 PM
