67 fstbk need help
I prefer a little firmer ride than 2+2GT, so I went with mostly the same setup as Jonk. The ride is firm but not overly jarring, although I run Edelbrock IAS shocks as opposed to the super stiff Gas-A-Justs. The Shelby drop and roller perches made the most difference in handling and suspension response.
ok, So if i'm going to go with a 351 based stroker should i get different springs up front then if i were going 289-302 based. My rear tires are almost touching the fenders in the rear so it must have been lowered in the back? I do have 17" TT
Take a look at your axles where the springs bolt to them and see if there are lowering blocks installed http://www.mustangsunlimited.com/ProdImages/LB106-C.jpg . If not the rear leafs may just be shot and sagging (40+yrs.) as mentioned airshocks are usually a sign that someone tried to stop the rear suspension from moving through it's travel due to rubbing or to jack up the rear to 'fix' sagging. Most leafs come standard (high back end like the cars were orginal ~2"+ above the tires) mideye (drops it ~2" to bring it ~level with tire tops, what I have) or reverse eye (3"+ drop puts the tires into the fender well if they're tucked). What ride height are you looking for?
When you have one of your tires of you need to measure your backspacing on the rims - distance from the back mounting area of the rim to the lip of the back of the rim = 3.75", 4.25", etc.
Jon
