front marker lights?
Old Dec 28, 2009 | 12:13 PM
mortman's Avatar
mortman
Default front marker lights?
Is there a way to add blinkers to the front marker on a 68 coupe?
Old Dec 28, 2009 | 12:46 PM
2+2GT's Avatar
2+2GT
Sure- Gut the socket from the housing, and add the socket and pigtail for an 1157 bulb, and splice it into the wiring harness. Why, though?
The turn signal on the front is highly visible, because, unlike modern cars, it is not part of the headlight housing, it's completely separate. If you want greater visibility than that, use a white bulb instead of a yellow one, and if you REALLY want to blow people away, use an LED turn signal.
http://www.amazon.com/Super-Intensit.../dp/B000Y3D3Q6
Old Dec 28, 2009 | 07:29 PM
67t5ponycoupe's Avatar
67t5ponycoupe
My 67 had 68 fenders so I wired the markers into the front turn signals and used the same marker wiring and a yello bulb. I liked it becasue cars beside me on the highway could see that I wanted to change lanes. I really like it and it was not that hard to do.
Old Dec 29, 2009 | 06:59 AM
tx65coupe's Avatar
tx65coupe
I'm not sold on the LED bulbs. They don't seem to provide uniform illumination in exterior lights or the instrument panel. When they are used in tail lights etc they seam to only produce light straight back and not to the sides at all.
I would also like to ask why you want to do this. Since they are on with the parking lights or headlights, you would want to make them flash opposite of the turn signals like the GM trucks.
Old Dec 29, 2009 | 08:33 AM
mortman's Avatar
mortman
Thanks for the input, ill try both options. as for why? better visability while driving in the city, i know there low and most probably wont see them in am attempt to change lanes but its worth a shot.
TfcCDR
Sep 14, 2015 12:08 PM
Sparks_88
Sep 8, 2015 01:06 PM
amandahchase
Sep 3, 2015 10:09 AM
