I took the Mach 1 down from the lift today, and started her up. I moved her down to the end of the driveway so I could do some vehicle manuvering. After I was finished I went to put the Mach 1 away and when I turned the igniton switch to off, the engine kept running. I pulled the coil wire to the distributor in order to shut the engine off. I then tried the ingition switch to see if it still worked. It worked when I tried to turn over the starter motor. Before I start tearing her apart i was wondering if anyone had an idea where to start. (In order to expidite the troubleshooting). Ignition switch? Starter relay?Corroded ground out connection from the switch? I drive the Mach 1 rarely these days (winter) so wire connections are always suspect. Thanks.
I have a quick question... How did you pull the coil wire and not get shocked?
Insulated channel locks....trust me, I was well aware of the chances of being jolted. And by the coil wire I mean the plug wire that feeds the distributor.
