heater core location?
Old Mar 19, 2010 | 09:31 AM
waldo786's Avatar
waldo786
Default heater core location?
I don't know much about heat and AC but is my heater core located in the dash?
Old Mar 19, 2010 | 09:46 AM
kalli's Avatar
kalli
yes. under the dash, about where the glovebox is. it's a huge plastic box where a few cables from the console for operating the flaps go to.
you should have two hoses connecting to it from engine side to firewall. if they're deleted, the heater fan sits in the same box
that is if you're talking 64-66 models. the rest i don't know
Old Mar 19, 2010 | 02:18 PM
2+2GT's Avatar
2+2GT
What year is your car?
Old Mar 19, 2010 | 03:34 PM
waldo786's Avatar
waldo786
Yes, the car is a 66. Thanks I'll do some checking in there next time I'm working on it.
Old Mar 19, 2010 | 04:12 PM
71Mach14spd's Avatar
71Mach14spd
If you have a/c you will have to drop the box, and if its functioning a/c then you might just want to take it to a a/c guy because you will have to discharge the system and its a real pain in the rear. If its none a/c and or its not functioning a/c then you just drop the box take it apart and put the new one back in put it back together, fill up on coolant and your good to go.
Old Mar 19, 2010 | 06:52 PM
2+2GT's Avatar
2+2GT
Not in a 66. The heat and AC are totally separate units in 66.
The heater can be removed from a 66 in under a half hour, and this is definitely the way to go- if you try to work on it in the car it might kill you, and you'll probably destroy it.
Replace the foam seals while you have it out.
Old Mar 19, 2010 | 08:02 PM
71Mach14spd
You learn something new everyday, never knew they were separate in that year.
mrtrodonet
Sep 19, 2020 03:12 PM
Seanam
Oct 4, 2015 10:15 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
jstrothe
Sep 24, 2015 12:17 PM
allenmaty
Sep 24, 2015 09:17 AM
