1966 Master Cylinder
Old Apr 6, 2010 | 01:29 PM
findads's Avatar
findads
Default 1966 Master Cylinder
My newly acquired mustang has the manual rear drums and front disc brake setup. It needs a new Master Cylinder. I read somewhere that I should change from the stock single resevoir to a dual reservoir setup. Can someone provide advice including why you made (or didn't make) the change and if changed, the parts you used?
Thanks much in advance!
Old Apr 6, 2010 | 01:46 PM
2+2GT's Avatar
2+2GT
Use a 1967 manual drum cylinder and the 66 pushrod. You'll need a universal master cylinder line kit, and a plug and inline connector to connect the master to the 66 brake lines and distribution block.
Old Apr 6, 2010 | 03:40 PM
xswoopr's Avatar
xswoopr
You absolutely should change to a dual MC for peace of mind. If your single reservoir fails you have no backup. I have the same setup as you and put in a new master cylinder for a '74 Maverick, I believe it cost me about $20. It works great and was an easy install, just needed a washer spacer and all was well. You'll also need to install a proportioning valve.
Old Apr 6, 2010 | 05:06 PM
chockostang's Avatar
chockostang
The 74 Maverick Front Disc, Rear drum, MANUAL Disc master has the internal clip ring machining to retain/keep the push rod in from falling out.
The Power Disc Masters do not, the push rod has no means to keep the push rod retained in the piston.
The original push rod , with clip, will function fine.
One more bit of info---Install a New Master, not a used, rebuild?? With unknown internal faults you won't know about till you need it.
Dan @
ChockoStang
Old Apr 6, 2010 | 06:18 PM
david01130's Avatar
david01130
I am in the same boat. I bought a 65 mustang but the owner put a dual master cylinder in from a 67 or 68 mustang I believe but did not hook it up. He gave me the distribution block but I still need to get some brake lines made up to connect it all.
Old Apr 6, 2010 | 07:06 PM
Oxnard Montalvo's Avatar
Oxnard Montalvo
1974 Maverick MC bolts right in FTW.
Old Apr 6, 2010 | 10:41 PM
findads's Avatar
findads
Thanks everyone! I ordered the 1974 Maverick MC today.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
b8checker
Oct 8, 2015 12:55 PM
Dathan
Oct 5, 2015 05:52 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
