It Happened!
Old May 17, 2011 | 08:27 PM
  #311
Gun Jam's Avatar
Gun Jam
So thats an affirmative on the blue oval?...Remember it was my idea
Old May 17, 2011 | 08:29 PM
  #312
1slow67's Avatar
1slow67
ROTM Moderator
I dislike any pony emblem, mustang script, and ford logo on mustangs exterior.
Old May 17, 2011 | 08:35 PM
  #313
hightower2011's Avatar
hightower2011
I like it a lot now.
Old May 17, 2011 | 08:48 PM
  #314
1slow67's Avatar
1slow67
ROTM Moderator
I'll install my antenna tomorrow. Think I am going to put it at the top of the passenger side windshield.
Old May 23, 2011 | 03:45 AM
  #315
tx65coupe's Avatar
tx65coupe
I'm so glad to see it back together and all. I bet your more than happy about it.
I'm still going to have to give you crap about the new 5.0 badges.
Old May 25, 2011 | 09:18 PM
  #316
1slow67's Avatar
1slow67
ROTM Moderator
Well any recommendations for pistons or rods? Thinking about upgrading my cam as well.
Today it decided to send a nut or two from a rod cap through the oil pan.
Old May 25, 2011 | 10:04 PM
  #317
spdrcer34's Avatar
spdrcer34
ouch...
Sorry about the engine!
Old May 25, 2011 | 10:23 PM
  #318
Jonk67's Avatar
Jonk67
I'd hang that on the garage wall.
I tried to do an affordable quality build and discussed it with my engine builder who has competed in the Engine Masters challenge a few times.
I ended up with an Eagle cast crank, Eagle 5140 Steel SIR I-beam rods and KB hyperteutectic pistons. This is in a stroker but I'm sure they sell stock size stuff too.
I also went with a compcams XE262 which was the tallest cam that still puts out close to stock vacuum for my PB & AC. It's a hydraulic flat tappet cam though and I've got AFR heads w/screw in studs. I don't know about the rollers but rule of thumb with the stock heads is anything close to .500 lift and you are getting close to pulling the studs out if they're pressed. You can download CC Camquest program and play with it putting in different variables and it'll suggest 3-4 cams. I like changing things to see what it does to cam suggestion.
Sorry for your troubles, I'm curious to see what let go when you get the pan off. You sure the rods were put back in the same order they came out? Did you use new rod bolts?
I take it you reused the original crank, rods, pistons and just did new bearings and rings. Was the proper torque sequence followed, bearing preload checked, crank turned, etc?
I don't know about the later motors but the early 289/302 are said to have weak rod bolts and I went with ARP on forum suggestion and builders suggestion.
Jon
Old May 25, 2011 | 11:11 PM
  #319
Gun Jam's Avatar
Gun Jam
that sucks dude...that engine was just rebuilt right?
Old May 26, 2011 | 12:26 AM
  #320
1slow67's Avatar
1slow67
ROTM Moderator
Actually was a new oem crank. I used a different set of pistons(HO) and rods(F2) than what came out. And yes, I have less than 50 miles on the engine since I put it together. it shouldn't have done this so we are going to see what happened.
