It Happened!
Old Feb 20, 2011 | 08:55 PM
  #211
1slow67's Avatar
1slow67
ROTM Moderator
Originally Posted by NoReins
Wow cool, man. Looks like you can put those sweet emblems on afterall!
Your project is coming along nicely as well!
  #212
1slow67's Avatar
1slow67
ROTM Moderator
Old Feb 20, 2011 | 09:18 PM
  #213
hightower2011's Avatar
hightower2011
Originally Posted by BA Mustang
Well I got the engine completely disassembled, also found the casting number and found out it is an 87 block. It along with the heads and crank will be taken to a speed shop and be dipped. While they have it they are going to replace my cam bearings and maybe the freeze plugs.
Do you know yet what that's gonna cost you? I've been meaning to check around machine shops locally to see what it'll cost me to get the block cleaned up, maybe the heads too...
Old Feb 20, 2011 | 09:29 PM
  #214
1slow67's Avatar
1slow67
ROTM Moderator
Not a clue on the price, I doubt it will be much since my grandfather is friends with the owners of the shop. They have done a couple of his engines as well.
Old Feb 20, 2011 | 09:41 PM
  #215
mr_velocity's Avatar
mr_velocity
Shouldn't be too bad, I think I put $900 into mine which included boil the block, touch up the hone, replace all the rod bolts with ARP and resize them, clean up the pistons, balance the rotating assembly, new bearings and rings. Probably a few other things I forgot about. Not being in the over priced state of NJ you could probably get it done for 1/2.
Now I think I need to unwrap the motor tomorrow and do some work on it. Getting cold up here again
Old Feb 20, 2011 | 09:56 PM
  #216
1slow67's Avatar
1slow67
ROTM Moderator
Yeah as of right now there are only going to dip everything and then press in new cam bearings. I will be doing everything else with the help of my dad and grandfather.
Engine is going to be ford blue, while the intake, valve covers, and water pump will be gloss black.
Old Mar 22, 2011 | 10:29 PM
  #217
1slow67's Avatar
1slow67
ROTM Moderator
Hmmmm... if I ever autoX this car I feel like I'd run these.
EDIT: Bronze ones aren't bad either.
Old Mar 22, 2011 | 10:35 PM
  #218
Sxynerd's Avatar
Sxynerd
SICK!
Old Mar 22, 2011 | 10:45 PM
  #219
1slow67's Avatar
1slow67
ROTM Moderator
They are only $120 a piece for 16x7s, I paid more a piece for my 15s on there now.
I do feel like if I bought these, there wouldn't be enough chrome on the car to balance out all of the red.
Old Mar 23, 2011 | 06:36 AM
  #220
tx65coupe's Avatar
tx65coupe
I much prefer the wheels you have now to those.
