Transmission mount replacement questions
Old Apr 25, 2010 | 02:16 PM
paddy187's Avatar
paddy187
Default Transmission mount replacement questions
I have a few question above replacing the transmission mount on my 65. I have the basic idea down, i.e. undo bolts on cross member to transmission, support transmission, raise trans, remove cross member, unbolt mount from transmission and then put back together. My question is were is the best place to support the transmission?
Cheers
Old Apr 25, 2010 | 02:28 PM
2+2GT's Avatar
2+2GT
Cheers
How about supporting the trans tailshaft, loosening the mount bolts, raising the trans, and replacing the mount without removing the crossmember?
Old Apr 26, 2010 | 08:47 AM
paddy187's Avatar
paddy187
I take it that is the position before the U-joint to drive shaft? will that effect the rear trans seals and also will that effect the shifter and consule? Sorry, I just like to double check stuff to make sure I am doing it right or at least less wrong!!
Old Apr 26, 2010 | 11:51 AM
2+2GT's Avatar
2+2GT
It should have no effect on the seals. The shifter should allow an inch or two vertical movement. The console should not be effected in any way.
Old Apr 26, 2010 | 01:47 PM
paddy187's Avatar
paddy187
2+2 GT, Thanks alot for you advice it is much appriacated, even if I can't spell!!
classic69FB
Aug 12, 2015 11:58 PM
Soldier GT
Aug 12, 2015 03:46 PM
Mnuckolls
Aug 9, 2015 08:54 AM
Itstbrown
Aug 9, 2015 03:49 AM
