front springs
Old May 2, 2010 | 05:59 PM
1967coupeon101's Avatar
1967coupeon101
Default front springs
I can not compress the spring enough to put it back on top of the Upper Arm perch. What should I do? I need to compress at least another 2 inches and even then it'll still be tight.
I have to internal, 4 hook style compressor
Old May 2, 2010 | 06:26 PM
rtintwo's Avatar
rtintwo
Have you compessed it to the point that the coils are touching or is the commpressor just slipping around on you?
Old May 2, 2010 | 07:04 PM
2+2GT's Avatar
2+2GT
The spring compressor you describe is dangerous junk. You need one the sets above the shock tower and draws the spring upward using a disc that can't slip.
Old May 2, 2010 | 07:06 PM
1slow67's Avatar
1slow67
ROTM Moderator
I agree
Old May 2, 2010 | 07:13 PM
67mustang302's Avatar
67mustang302
Yeah, find the one in the pic, those other ones can do some serious injury to your body. Springs when compressed contain HUGE amounts of force. Say you're installing 620 springs that actually have a 620lb/in rate....if you compress it 2" then it has 1,240lbs of stored energy, compress it 3" and it has nearly 1 ton of stored energy. And that doesn't even include the energy imparted due to velocity when contact is made.
Old May 2, 2010 | 09:08 PM
1966-FASTBACK's Avatar
1966-FASTBACK
go to EBAY and type this in---65-73 Mustang Shelby Falcon Coil Spring Compressor---he makes a spring compressor that works like a charm-$55.00. i had the same problem as u till i got this.
4cylinderplus2
Oct 9, 2020 07:45 PM
baddog671
Jul 26, 2016 01:20 PM
marc954
Sep 29, 2015 11:18 AM
mungodrums
Sep 28, 2015 10:54 PM
