Head Unit/ Alt Question
Old 08-07-2005, 04:01 PM
Riven02
Riven02's Avatar
Default Head Unit/ Alt Question
I have a 1965 Mustang 289 with a factory equivalent altenator. Will I have to upgrade the alt to put in a nice head unit? It currently has a Jensen CR225X which fits into the factory hole. I am going to leave that in there and put a good headunit the in glove box. I dont plan on running any amps, it would just be a headunit probably 50*4W peak max. The lights do dim with the AC, radio, and high beams on when I slow to idle but I wasnt sure how much more draw a good radio would have over the Jensen. (They would never be on at the same time)
Riven02 is offline
Old 08-07-2005, 08:14 PM
nualln
nualln's Avatar
Default RE: Head Unit/ Alt Question
Man I run a JVC head with a boss 400w amp powering 2 subs. I can see the instrument lights dim at idle when its raining outside, the wipers are on, the highbeams are on and the radio is blasting.
You should be fine.
nualln is offline
Vrooom
02-21-2016 05:25 PM
EASTIDEE123
09-14-2015 03:52 PM
cbird1177711
09-02-2015 08:51 PM
cbird1177711
09-02-2015 04:12 PM
Quick Reply: Head Unit/ Alt Question
