A/C unit
Old Sep 13, 2010 | 12:44 PM
Galactusz's Avatar
Galactusz
Default A/C unit
Does this A/C unit look complete?
The guy says it works, and it's for a 64-66.
He says it works for both V8 and six cylinder.
Is this true, or is he pulling my chain?
Thanks!
Old Sep 13, 2010 | 01:08 PM
2+2GT's Avatar
2+2GT
The RH side cover and drain are missing from the evaporator, The mounting brackets are missing from the condenser, and all of the lines and hoses, and pulleys, brackets, and compressor are missing.
It's true, though, the parts you have are the same for 6 or 8 cylinder.
Old Sep 13, 2010 | 01:12 PM
Galactusz's Avatar
Galactusz
Is it hard/expensive to find all those missing parts?
The guy wants $300 for this unit, and he guarantees it works.
I appreciate your help..thanks.
Old Sep 13, 2010 | 03:29 PM
2+2GT's Avatar
2+2GT
Everything that's missing is available. As for "works", you can only verify that the blower fan in the under dash unit runs, unless you install them as part of a system. I have used many used under dash units with no problem, including the one in my car for the last 40 years. The condenser may be OK, too. The receiver/dryer is junk, it has been exposed to the air (no plugs in photo) and the dessicant is now trashed. $300 for a working under dash unit is a good deal, if in good condition. Photo is kinda small to check the chrome, but it looks OK in the teeny photo. You'll need new registers, of course.
The hoses attached may well be useable, too, but I don't know what engine they are for, or which you have.
Old Sep 13, 2010 | 09:00 PM
Galactusz's Avatar
Galactusz
Thumbs up
Thanks man...much appreciated!
Old Sep 13, 2010 | 09:46 PM
msmith's Avatar
msmith
In case it matters to you, that is a 1965 unit. The 1966 units had the black "camera" texture on the front panel, instead of the silver of that unit. There should also be a date stamp on the fan housing
Old Sep 13, 2010 | 11:26 PM
Galactusz's Avatar
Galactusz
Thumbs up
65 is even better!
Old Sep 14, 2010 | 05:36 AM
2+2GT's Avatar
2+2GT
True, and it was more than just a cosmetic change, the 64-65 unit was offset slightly to the right, while the 66 was centered.
vargas
Jun 17, 2017 12:17 PM
baddog671
Jul 26, 2016 01:20 PM
kevsgt
Oct 9, 2015 10:12 PM
lincolnshibuya
Oct 6, 2015 08:45 AM
jrrhd73must
Oct 2, 2015 09:17 PM
