fuse box on 71
Old Sep 21, 2010 | 06:32 PM
bw71mach1's Avatar
bw71mach1
Default fuse box on 71
I have one fuse in the fuse box that never has power. It is the small one in the center that powers the gauges. Any advice on how to trouble shoot this?
Old Sep 22, 2010 | 12:28 AM
andrewmp6's Avatar
andrewmp6
All i can think of is just wire around it and run a inline fuse its not pretty but will work fine.
Old Sep 22, 2010 | 07:18 PM
bw71mach1's Avatar
bw71mach1
The gauges have to run thru the voltage regulator on the back of the instrument panel correct? I would have to run the new wires thru the regulator right?
Old Sep 22, 2010 | 10:24 PM
71fast's Avatar
71fast
The power to the voltage regulator does not go through the fuse panel. The #10 black with green hash colored wire from the ignition switch is factory spliced to a #18 black with green hash colored. The splice is inches from the fuse box inside the wiring harness. The number 10 feeds fuses F5, F6, and F7. The number 18 feeds the voltage regulator that feeds the fuel, oil, and temp gauges. Does the fuel gauge work? On the dash panel printed circuit board you will find the regulator that should measure 5VDC.
Old Sep 26, 2010 | 06:23 PM
bw71mach1's Avatar
bw71mach1
Yes the fuel gauge works. I guess I'll have to just go hunting. Thanks for the help.
Old Sep 27, 2010 | 07:11 PM
71fast's Avatar
71fast
The fuel gauge working means the 5 volt regulator is probably ok. Does the amp guage work ok? I could PDF you a wiring diagram if I had your email. Not sure how to post a PDF to the forum.
Old Sep 27, 2010 | 07:33 PM
bw71mach1's Avatar
bw71mach1
I just figured out that the fuse is okay. I misread the diagram. So it appears that I don't have power going to the plug that powers the amps/temp/oil. I'll pm my email address to you.
Old Sep 27, 2010 | 07:40 PM
bw71mach1's Avatar
bw71mach1
I can't send you a private message. You must have it turned off.
jwog666
Dec 27, 2021 08:09 PM
baddog671
Jul 26, 2016 01:20 PM
daltron
Apr 28, 2016 08:10 PM
daytooday
Sep 20, 2015 10:55 AM
cbird1177711
Sep 2, 2015 04:12 PM
