found a 9 inch
Old Oct 14, 2010 | 11:00 PM
torino420's Avatar
torino420
yea...5 on 5.5" is Ford Truck/Bronco bolt pattern, Mustangs are 5 on 4.5". Whats the width of the housing?
At least the housing is good, trucks got the beefier housing.
Old Oct 15, 2010 | 10:19 AM
dterry68's Avatar
dterry68
So all I would have to do is change the axles and the gearing if I wanted to right?
Old Oct 15, 2010 | 12:10 PM
torino420's Avatar
torino420
assuming its not too wide yes, but the truck housing is likely too wide.
Plus the spring perches will have to be flipped and relocated. Trucks had the leafs on top of the housings, mustangs are under it.
Post some pics if you can.
Old Oct 15, 2010 | 04:03 PM
dterry68's Avatar
dterry68
Ok thanks for the help ill try to post some on Monday it isn't at my house.
Old Oct 16, 2010 | 02:49 AM
andrewmp6's Avatar
andrewmp6
If its a truck housing probably have to be shortened and new axles ordered to fit it.
Old Oct 16, 2010 | 10:14 AM
69mach1377's Avatar
69mach1377
Axles with the correct bolt pattern...sometimes a good deal ain't so much.
Old Oct 24, 2010 | 12:30 AM
dterry68's Avatar
dterry68
Well I looked at it and thepumpkin had c5aw on it and it had 28 splined axles and 3.70 gears well around there. From inside flange of the housing to inside flange of housing it was 54 inches.
Old Oct 26, 2010 | 07:48 PM
dterry68's Avatar
dterry68
sorry the housing was 56 inches and to the end of the drum brakes was around 59 1/2 inches.
jerrytubes
Oct 23, 2015 12:11 PM
Dokilar
15
Oct 16, 2015 08:13 PM
jrrhd73must
Oct 2, 2015 09:17 PM
KingRando
Oct 2, 2015 08:06 AM
mungodrums
Sep 28, 2015 10:54 PM
