Who would do this...would it work?
Old Nov 8, 2010 | 01:10 PM
CyprusMustang's Avatar
CyprusMustang
Default Who would do this...would it work?
im thinking of buying a 1986 mustang for parts, its got a 351 in it, nice radiator with electric fans, a/c, nice seats, guages, nice radio and speakers etc...
now my question is, could i swap all the above into my 69? are the engines of 82-94 mustangs the same case size? if I dont end up buying this one maybe ill look for another. could you remove the efi and manifold off a an 82-94 mustang and replace with a carb?
Old Nov 8, 2010 | 01:14 PM
CyprusMustang
oh yea and an important factor, my tranny runs high rpm on highway and would use the manual tranny from the stang complete with the engine.
Old Nov 8, 2010 | 01:18 PM
2+2GT's Avatar
2+2GT
If this car has the T5 trans then yes, it's quite easy to put the 351/T5 setup in your car, and yes, you can bolt a carb intake directly on. Changing the distributor may be required.
Old Nov 8, 2010 | 01:29 PM
CyprusMustang
thanks, the engine mounts line right up? that means casing is the same..... also would i need to change anything from the tranny back? also, if the car has a 9inch, would i be able to change it with my one?
Old Nov 8, 2010 | 02:06 PM
bbcobra's Avatar
bbcobra
this swap is very common. I've been thinking of doing a restomod with a 4.6 4v engine. Some scoff at this but they look really cool in an old stang. You have to remove the shock towers to do it though.
Old Nov 8, 2010 | 02:16 PM
kalli's Avatar
kalli
not for a 86 351 though
Old Nov 8, 2010 | 02:36 PM
CyprusMustang
any cars for sale in the NY state area?
Old Nov 8, 2010 | 05:22 PM
.boB's Avatar
.boB
The Mustang was available in '69 with a 351W. I'm not sure about the 351C, but I don't think that was available until 1970? Either one will bolt right into your car using off the shelf parts. In '69, everything had a carb (almost), so that's easy, too.
In '86, the Mustang was not available with a 351 of any kind. So then the question is, what year is the 351W in that '86 you're looking at? Some were good, some not so good.
As for the other parts, none of them will bolt right in with factory parts. But, you can make them work if you buy the right aftermarket parts. For example, the T5 is considerably differant than a toploader. But you can buy the right clutch linkage parts and crosss member to make it almost a bolt in. Almost.
Old Nov 9, 2010 | 04:08 PM
bbcobra's Avatar
bbcobra
yeah, I was talking about the 4.6 4v engine.
the 69 can hold a 428 big block no problem. the newer mod motors are wider. any 302/351 engine will fit no problem.
1TUFF302
Nov 5, 2015 04:02 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
JoshyGT
Sep 7, 2015 02:04 PM
cbird1177711
Sep 3, 2015 08:43 PM
