t5 swap question
Old Nov 11, 2010 | 05:33 PM
CyprusMustang's Avatar
CyprusMustang
Default t5 swap question
i bought this kit https://www.mustangsunlimited.com/Pr...RA670534-C.jpg
what kind of pedal assembly would i need?
Old Nov 11, 2010 | 05:34 PM
CyprusMustang
would i need anything else?
Old Nov 11, 2010 | 07:28 PM
Gun Jam's Avatar
Gun Jam
Mustang steve offers a nice assembly that is bearing supported..I think it will work on the 69s you'll have to look
Old Nov 12, 2010 | 08:18 AM
2+2GT's Avatar
2+2GT
None. You'll need a clutch pedal, of course, and either buy a brake pedal or cut down the one you have. You'll also need a limit stop for the clutch pedal. The pedal support bracket is the same either way. Really.
You probably didn't need the slip yoke they sold you in that CPC kit.
Old Nov 12, 2010 | 08:58 AM
kalli's Avatar
kalli
i think I used the very same kit. it's for using the T5 with original bellhousing, not T5 bellhousing.
I brought the adapter plate to a machine shop to get the bellhousing drilled and tapped 100% perfect. (better than me with wobbly drillbits *g*)
anyway, in my case the bolts that hold the transmission to the adapter plate were too long. they bottomed out at the bellhosuing, so I couldn't get it all bolted together flat. Make sure to check on that
Old Nov 12, 2010 | 02:33 PM
TexasAxMan's Avatar
TexasAxMan
kalli, I think you're seeing it wrong, that kit is for using the T-5 bellhousing. And I agree, you won't need that slip yoke.
Old Nov 12, 2010 | 03:12 PM
mySAVIOReigns's Avatar
mySAVIOReigns
This kit is for using the original bellhousing - here's MU's quote: " The original bellhousing must be modified for installation. "
Notice in the picture the adapter is adapting the T-5 body to the small-side of the bellhousing. If it was for the T-5 bellhousing, the adapter plate would be much larger, and it would be adapting the larger side of the bellhousing to the 67's engine block.
Old Nov 12, 2010 | 05:53 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Y'all are mixed up. The kit shown is for an original bell housing and allows you to put the T-5 behind it using the adapter shown. A T-5 bell housing is a bolt in for a small block with no adapters needed other than you need to figure out how to make the clutch fork work by either going with a cable clutch or using the early style fork and fulcrum and spaceing the fulcrum out 1".
04stangman
Sep 17, 2015 01:45 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
jaiidutch
Sep 14, 2015 10:29 AM
97SN95GT
Sep 13, 2015 09:45 PM
