Spindle ID help
Old Dec 3, 2010 | 04:05 AM
jp1967stang's Avatar
jp1967stang
if you dont want to mess around with finding everything and what not but dont want to spend alot of money heres a full kit with everything you need for front disk brakes. Has master cyl, all lines, porp value the whole bolt in set up. I used this one on my car slotted rotors really nice kit.
http://www.opentrackerracingproducts.com/discbrakes/
Old Dec 3, 2010 | 11:15 AM
57sc's Avatar
57sc
Thanks for all the replys. Yes, I am going to convert to discs.
Yes, mine is a stock V-8 -260
So, from what I gather, I should just use my original spindles and start the conversion from there up. Correct?
Old Dec 3, 2010 | 11:38 AM
mr_velocity's Avatar
mr_velocity
That's what I would do, just give Dan a call at Chockostang and be done.
fwiw, this is the route I was going to take until I priced out all the other suspension work I was going to upgrade. Still can't figure out why someone would want to replace mustang spindles with granada spindles with the geometry issues it created. There is a lot of debate on this point and it primarily comes down to one thing, at least from what I could find, cost. You might save $100 changing spindles but its not worth the problems you'll create and when you're done buying the bumpsteer kit you're right back up there in cost.
In the end I decided to bite the bullet and just do a full coil over in the front with power r&p and big brakes.
winner99
Sep 30, 2015 07:04 PM
KillSwitchNY
Jan 10, 2006 12:38 PM
CrdStang
Sep 19, 2005 01:02 AM
67CarolinaCoupe
Sep 13, 2005 07:22 PM
eZ
Jul 13, 2005 12:53 AM
