good place to get a 66 windshild.
well i need a windshild.
where is the cheapest place to get one that dose not want as much for shipping.
also, at the same time im going to install a new head liner, should i replace the rear glass seal also?
I bought mine from a local glass shop. I think it was 120 (tinted)
Buy new rubber gaskets for both front and back. It will save you lots of frustration and possible leaks
Good Luck and Be safe
Ron
Ron
You should be able to get a 64-68 windshield banded/tinted glass locally, unless you want "date coded show correct", or clear.
Check with the local Mustang club for sources.
found one at technaglass for $97.00 ordered front and rear gasket's and clips from mustangpartshouse $61.00
found a place to install the headliner for $150
seem's a little high for not willing to even look at the glass. and technaglass want's 75 to put the glass back in. ill just cut out the glass.
