Carburetor help!
Old Jan 6, 2011 | 01:41 PM
Rols574's Avatar
Rols574
Default Carburetor help!
I just installed an edelbrock 1406 and i dont think its getting any gas in. how can i check to see the amount of gas being sent and adjust this?
Old Jan 6, 2011 | 04:22 PM
2+2GT's Avatar
2+2GT
There is no adjustment to flow, other than float level, and this is preset. Not starting, then? The fuel pump should fill it with about 5-10 seconds of cranking.
Old Jan 6, 2011 | 05:57 PM
scootchu's Avatar
scootchu
Put a fuel pressure gauge inline before the carb. I believe Edelbrocks like no more than 6.5 psi fuel pressure.
You should also see a squirt of fuel looking inside the front of the carb when you move the accelerator pump too.
What makes you think it's not getting fuel?
Old Jan 7, 2011 | 05:06 AM
kalli's Avatar
kalli
edelbrocks i'd even go 6 max, rather 5psi. and yes
with engine off, open the choke butterfly and press the throttle. If you see gas squirting then you know the carburetor is getting fuel
Old Jan 7, 2011 | 06:54 AM
tx65coupe's Avatar
tx65coupe
I'll also say that Edelbrocks do not like more than 6 psi maximum fuel pressure. I had a different pump and was getting about 7 psi and the carb did not like that at all. I think Kalli is right about keeping it more like 5 psi.
Since we are talkinga bout this, how much pressure does a stock fuel pump produce? I have never seen specs for them. I have the edelbrock pump that is spec'd at 6 psi.
Old Jan 7, 2011 | 08:34 AM
Starfury's Avatar
Starfury
Depends on the pump, but usually 4.5-7psi.
5.0pntydrpr
Aug 27, 2015 10:26 PM
valley firearms
Sep 7, 2005 04:21 AM
DSMtuner
Aug 4, 2005 04:12 AM
Valk
Nov 9, 2004 11:43 AM
TheGmKiller331
Feb 18, 2004 12:55 AM
