Eliminate roller spring perches
Old 02-11-2011, 06:26 PM
eZ
eZ's Avatar
Default Eliminate roller spring perches
Just another idea...Instead of buying roller spring perches you can eliminate them all together and have an adjustable system.
Uploaded with ImageShack.us
All the mounting is in the stock location. I know the pic is of a custom UCA but it would mount to a stock one. QA1 offers the T bars for mounting. You would need 3.5'' for top and 5'' for bottom. Youd be able to run a lighter spring as well. Like a 450 or so.
eZ is offline
Old 02-11-2011, 06:36 PM
2+2GT
2+2GT's Avatar
Looks like you have a regular old bushing on that one, except it appears to be urethane.
2+2GT is offline
Old 02-11-2011, 06:41 PM
eZ
eZ's Avatar
correct but the spring is not rotating on it. The spring stays inline with the shock.
eZ is offline
Old 02-11-2011, 07:15 PM
2+2GT
2+2GT's Avatar
The arm rotates, exactly like a stock arm, around the bushing.
2+2GT is offline
Old 02-11-2011, 10:59 PM
JMD
JMD's Avatar
Is it an optical illusion? To me, the lower shock mount appears to be bent downward...
And I hate to be one of those critical guys, but I think I would run grade 8 bolts in that location instead of the grade 5... at least they seem to be grade 5 to my eye...
I know, those bolts are not ordinarily in tension, but still, grade 8s are cheap enough.....
And.... (damn, I don't want to sound like a dick..) if I was running that setup I would probably want those tabs where the lower shock mount hooks to extend across and connect to each other. the strength of the setup would be way stronger. The tabs look like a weak spot to me. (to me it looks prone to metal fatigue, especially with only one bolt through it, due to tiny amounts of flexing of the brackets.)
IDK, I might just be paranoid, I guess the stock perches would mount the same way, but I worry about stuff that holds the car up.
I do like the simplicity of the setup though.
JMD is offline
Old 02-12-2011, 12:35 PM
eZ
eZ's Avatar
JMD--LOL I agree with everything you said...Its not my car...Its the only picture I could find of this shock setup.
So stop being a d!ck LOL
eZ is offline
Old 02-13-2011, 07:56 PM
JMD
JMD's Avatar
LOL, I can't help myself sometimes, ask anyone who knows me...
JMD is offline
GimpyHSHS
19
12-19-2023 01:12 PM
CS2007
06-25-2019 09:45 PM
Florida Regional Chapter
09-30-2015 08:04 PM
mungodrums
09-28-2015 10:54 PM
Quick Reply: Eliminate roller spring perches
