1 step forward, 3 steps back
Old Feb 27, 2011 | 08:41 PM
groho's Avatar
groho
Default 1 step forward, 3 steps back
Slowly making progress stripping my coupe, so I can send it to paint. I've only got about 20% of the car left. Sanded down the passenger door today and discovered this rocker panel, which is gonna set me back at least a month or two fixing the problem. You can see the screw holes used to pull the rocker out with a slide hammer. The good news, the rocker is straight, and the damage does not go above the door to the top of the rocker nor the below the rockers underside, and I'm confident I can save the door. I have no problem welding, my question is primarily structural. Can you section a rocker, or do you have to replace the entire rocker panel? The damage is limited to the front half of the rocker.
Attached Thumbnails 1 step forward, 3 steps back-rocker1.jpg   1 step forward, 3 steps back-rocker2.jpg
Old Feb 27, 2011 | 08:45 PM
2+2GT's Avatar
2+2GT
You can, but your problem looks like most of it.
Old Feb 27, 2011 | 09:21 PM
001mustang's Avatar
001mustang
1st i would plan strategic location for weld seams.
if the rocker is not rusty i would cut out the bendy bits w/n welding strategy.
hard to duplicate OEM spot welds.
step back and evaluate.
can add some reinforcement behind rocker if your concerned about strength.
i would save whole rocker replacement option for last resort.
Old Feb 28, 2011 | 12:31 AM
Gregski's Avatar
Gregski
that looks like it took a good hit to cause that much damage what else did you find, also is that just bondo in the screw holes? they didn't even weld them up
drfister
May 3, 2018 10:38 PM
MustangGirl98
Aug 2, 2016 08:10 AM
mirandaandjimmy
Nov 16, 2015 08:51 AM
yourmom6990
3.7L V6 Technical Discussions
Oct 14, 2015 10:08 PM
waid302
Sep 14, 2015 11:19 AM
