Inline 6 Upgrades???
Old May 24, 2011 | 08:45 PM
Rat fink's Avatar
Rat fink
Turbo would get you an extra 100 hp and you wouldn't have to do all the other stuff.
Old May 24, 2011 | 08:52 PM
1slow67's Avatar
1slow67
ROTM Moderator
Youd just have to update the fuel system depending on boost amount. Keeping it under 10 psi would allow you to keep the stock internals. Then you would need an electric fuel pump and a nitrophyl float so that it doesn't crush under the pressure.
Old May 24, 2011 | 08:59 PM
2+2GT's Avatar
2+2GT
Originally Posted by wonso79
Thanks for the advice, I am getting the motor rebuilt over this winter and was looking at things to do to it to increase the horsepower. How much do the T-5 5 speed transmissions run?
IIRC, you can get a new one for about $1200. Rebuilt for less. Even decent used ones can be found. Installation cost depends what you have now. If the car already has a manual trans, that makes it easier and cheaper. If you have an auto trans, you'll need to get the clutch and bellhousing items, too.
Old May 24, 2011 | 11:17 PM
scott_m_mil's Avatar
scott_m_mil
If you google ford straight six performance or ford 200 straight six there are several sites with loads of information.
Old May 25, 2011 | 01:35 AM
Tilley's Avatar
Tilley
Wouldn't it be cheaper and easier to put in a V8?
Old May 25, 2011 | 05:31 AM
2+2GT's Avatar
2+2GT
No, because a V8 would require replacing the engine, transmission, driveshaft, rear axle, front and rear brakes, steering linkage, exhaust system, fuel lines, cooling system, engine wiring, and some other stuff I forget.
That's not cheaper OR easier.
Old May 25, 2011 | 05:44 AM
1slow67's Avatar
1slow67
ROTM Moderator
Yeah its really not, I found that out first hand.
good website I used was www.fordsix.com
Old May 25, 2011 | 04:48 PM
wonso79's Avatar
wonso79
I have a stock Inline 6, so what kind of transmission did they come with?
Originally Posted by BA Mustang
What transmission do you have now?
Old May 25, 2011 | 04:49 PM
wonso79's Avatar
wonso79
thanks!
Old May 25, 2011 | 05:59 PM
2+2GT's Avatar
2+2GT
In 1965, the 200 was offered with the 2.77 3-speed manual standard, optional transmissions were the C4 automatic, and the 4-speed fully-synchronized Dagenham manual transmission. The 65 200 could also be ordered with the 3.50:1 rear axle ratio, and Equalock limited-slip differential.
