67 Mustang Speedo Core Cable Replacement
Old Nov 18, 2011 | 05:20 PM
ClayTex's Avatar
ClayTex
Default 67 Mustang Speedo Core Cable Replacement
Ok... So... here's the problem I was having:
The speedometer constantly sounded like it was rattling fairly loudly. Occasionally it would start ticking and bouncing and the odometer would stop working; this would eventually stop and it would work "normally" just with the rattling sound.
I came to the conclusion that the cable probably just needed to be lubed. However, I figured for 7 or 8 bucks why not just replace the cable core and have a brand new core in there.
So... I take the old cable core out... cut the new one to length... and I can't for the life of me figure out how to get this little metal spike(vague instructions on the package called it a stake) onto the end of the cable to go inside the speedometer gauge. (The old one had a plastic one on the end of it that was actually pointed; the new "spike" is flat on the end.)
I finally decide to just stick the spike into the speedometer gauge and screw the cable back onto the back of the gauge and hope that time/friction/pressure will push the cable into the spike.
So... now... I go to test to see if it works... it seems to. The speedo jumps up for 0 to 10ish when I start moving and then climbs as I accelerate. Seems good right? I haven't been able to test the accuracy of my just-shove-it-together-and-let-it-work-itself-in speedometer job yet, though. However... the rattling sound has gone away. YAY! (Probably just had to do with the fact that I lubed the new core up when I put it in.
So... now my real question... and I'm going to show how little experience I have with these older vehicles here:
I never paid attention to whether or not the speedometer worked in reverse; yknow, I mean show how fast I'm going. But if it did before... it sure as hell doesn't now... So... Is it supposed to show my speed in reverse?
Old Nov 18, 2011 | 05:57 PM
2+2GT's Avatar
2+2GT
The generic cables I have seen should have the tip crimped on.
I always use the correct repro cables. They aren't expensive, and the better ones are the exact length.
Mechanical speedos don't work in reverse.
Old Nov 19, 2011 | 01:03 AM
ClayTex's Avatar
ClayTex
Yeah. I am feeling like i need to put the old cable back in and just lube it until i replace the entire cable set up (which will be soon). The old cable actually looked to be in really good shape.
Old Nov 19, 2011 | 09:07 AM
2+2GT's Avatar
2+2GT
I have an 8 oz tub of E6TZ-19581-A Ford speedo cable grease. My heirs will probably throw it away. Works really well.
I use gun oil on the speedo drive shaft. Never gets sticky or thick.
djbigskrilla
Sep 20, 2022 01:04 AM
Urambo Tauro
Dec 17, 2016 03:30 PM
Gun Jam
Oct 4, 2015 12:10 AM
daytooday
Aug 11, 2015 09:22 AM
Mnuckolls
Aug 9, 2015 08:54 AM
