68 Transmission question
Old Dec 7, 2011 | 02:45 PM
uvastang's Avatar
uvastang
Default 68 Transmission question
Ive got a 68 mustang with an automatic 3 speed c4 but im wanting to swap in a manual trans. I have flywheel pedals and bellhousing but my question is... Is there anyway to bolt a T-5 transmission to the 68 bellhousing? Or is there any other way at all to bolt up a T-5 ?? Thanks!!
Old Dec 7, 2011 | 04:13 PM
PaulS's Avatar
PaulS
There is an adapter that goes between the bell and the T5.
Paul
Old Dec 7, 2011 | 05:53 PM
uvastang's Avatar
uvastang
Thanks.. So thats all that I will need? Just the adapter?
Old Dec 7, 2011 | 08:00 PM
MonsterBilly's Avatar
MonsterBilly
Uh no, you will need a new transmission cross member, a shortened drive shaft, either a hydraulic clutch or a cable clutch set up, and you will also need to change the speedo gear in the T5. if you want details just do a search on this forum. You will find everything you need.
also, the bell housing for the T5 will bolt right up to your existing 289/302. so if you have the t5 bell housing you can just use it.
Old Dec 8, 2011 | 10:16 AM
wgc68nyc's Avatar
wgc68nyc
I believe www.cjponyparts.com has a kit with just the conversion parts needed minus the new pedal setup.
You maybe able to at least see what you still need.
AmericanMuscle4.6GT
Nov 10, 2015 02:06 PM
04stangman
Sep 17, 2015 01:45 PM
LivingInThePast
Sep 16, 2015 12:20 PM
vintageaion
Sep 8, 2015 10:45 AM
