explorer rear end swap??
Old 02-16-2012, 05:38 PM
2+2GT
2+2GT's Avatar
Originally Posted by frdnut
That all depends on how its used....My brother blew his 8 inch up this summer with about 300hp at most..Sticky tires at the dragstrip will find the weak points.
Was it the 4-pinion, 65,000 psi Traction-Lok from Currie?
2+2GT is offline
Old 08-02-2012, 10:50 AM
newtothisthing
newtothisthing's Avatar
Hello there, Im installing a rearend from a 94 Mustang GT on my 67, the question I have is in regards to the parking brake cables, will the 67 cable set up work with the 94 rearend disc-set up? and also what about the counterweight that is bolted on the 94 rearend? would you remove it or leave it?...Thanks
newtothisthing is offline
Old 08-02-2012, 02:55 PM
MonsterBilly
MonsterBilly's Avatar
I personally would remove everything that is not needed. I dont think the e brake will work. Locar makes a Ebrake handle to mount between the seats that works. Or grab the handle out of the newer stang and use it with the cable.
MonsterBilly is offline
Old 12-23-2014, 03:36 PM
MyStangIsAStrangeThang
MyStangIsAStrangeThang's Avatar
Default can you switch out the ring and pinion from a 90s explorer to a 2008 8.8?
Would the pinion depth be the same? Can I use the same shim? If so which carrier should I use?
MyStangIsAStrangeThang is offline
DCole24
09-11-2015 10:50 AM
91StangOwner
08-20-2015 11:34 PM
Black_GT_02
08-20-2015 01:26 PM
ding56
08-14-2015 02:40 AM
PearlGenPu
08-12-2015 01:57 PM
Quick Reply: explorer rear end swap??
