Okay my electrical problem.
Old Sep 24, 2005 | 08:23 PM
  #21
tylerdru's Avatar
tylerdru
Default RE: Okay my electrical problem.
With power to my bulbs and the bulbs not working could the shifter light have something to do with the bulbs not working I belive the same wire that connects the instrument panel bulbs also connects to the shifter light and then is grounded to the floor pan however when i removed the shifter plate nothing is hooked up Any Help?
Old Sep 24, 2005 | 09:29 PM
  #22
tylerdru's Avatar
tylerdru
How and where do i ground the bulbs? This will solve my problem!
Old Sep 24, 2005 | 10:24 PM
  #23
6mustang6's Avatar
6mustang6
They should ground to the instrument panel.
Old Sep 24, 2005 | 10:50 PM
  #24
tylerdru's Avatar
tylerdru
none of my light bulb housings have ground wires.rednecks these days. They cant do anything right!
Old Sep 24, 2005 | 10:52 PM
  #25
Cogtx's Avatar
Cogtx
Tyler..does the interior light come on when you turn the headlight switch all the way to the left? If not, the contacts on the switch are probably dirty or not making contact with the round spring like contact on the switch. I had to clean and bend the contact on my headlight switch "just enough" to touch the circular contact spring on the switch. Hope this make sense...good luck...
hope the photo helps...
[IMG]local://upfiles/19071/F08A3C1A7C9249C19E1165C6505882B9.jpg[/IMG]
Old Sep 24, 2005 | 10:58 PM
  #26
tylerdru's Avatar
tylerdru
Cogtx, I did get that problem fixed. I just bought a new one, But of course now none of my lights are grounded so they dont light up. Do I need to buy new light bulb housings with grounds on them? I now have power to all of the wires just need the grounding!
Old Sep 24, 2005 | 11:42 PM
  #27
6mustang6's Avatar
6mustang6
NO NO NO NO. They only have one wire, they dont have ground wires. They ground to the instrument cluster which should be grounded to the car.
Old Sep 24, 2005 | 11:49 PM
  #28
Cogtx's Avatar
Cogtx
Tyler...there should be no ground wire coming off of the instrument cluster lamps. The bulbs are grounded by the #57 solid black wire (that's the number from my '67 shop manual) found on the connector you plugged the instrument cluster in. Trace that black wire until you see that it is connected to a metal part of the vehicle. If that black wire is broken or has a bad contact, it won't supply the ground needed for the bulbs. Someone correct me if I'm on the wrong path here.
Old Sep 24, 2005 | 11:52 PM
  #29
6mustang6's Avatar
6mustang6
Yeah, thats what i was saying. I believe you are right there.
Old Sep 24, 2005 | 11:53 PM
  #30
6mustang6's Avatar
6mustang6
Since the sockets are getting power, then the ground wire probably is the only thing wrong with them, because it's a grounding issue.
