Trunk ideas?
http://mustangandfords.com/techartic...nk_carpet_kit/
ahhh found it!
im sooo tired....but i got hahaha. check it out, it looks beautiful.
ahhh found it!
Just build a box to fit the trunk. Then you could stuff amps, speakers, and woofers in there. Nobody will see the floor of your trunk. If you do put carpet back there, make sure your trunk don't leak.
Don"t forget SAFTEY !!! Cover the top of your gas tank with an 18 guage sheet metal,to contain the tank incase of a rear end colision! Also if you have a convt. ,sheet metal the back of the seat (in the trunk) with a 2 pc sheet metal 18 ga..Two pcs. are easer to fit than one.\
The naughad boot gives no protection in case of tank FIRE! Ford did a very poor job of SAFTEY on these cars!!
Good luck!
Good luck!
I was going to get Tank Armor and a rear divider Im making myself for safety. I was playing with the idea of carpeting the trunk but having the tank stick through becuase that armor would look awesome if chromed. Also, I want to put a barrety relocation back there. I got safety covered well I think and just playing with some ideas.
AMAlexLazarus
AmericanMuscle.com
Oct 1, 2015 09:21 AM
