fuel gauge question
Old Feb 1, 2006 | 10:38 PM
67t5ponycoupe's Avatar
67t5ponycoupe
Default RE: fuel gauge question
The quick fix is to take it back to the idiots that broke it.
Old Feb 2, 2006 | 07:25 AM
gizahuna's Avatar
gizahuna
Thanks, I'll give it a shot this weekend when I have more time. I'll keep you posted with the result.
Thanks again
Old Feb 2, 2006 | 09:24 AM
gizahuna's Avatar
gizahuna
One more question. Is the hole to feed the wire to the gas take located on the trunk bottom, on the side, near where the gas tank is connected or is it lower near where the lights feed up to the tail light wires?
Thanks
Old Feb 2, 2006 | 02:46 PM
Riven02's Avatar
Riven02
Its located on the FWD face of the tank.
Old Feb 2, 2006 | 06:27 PM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: Cogtx
here is a picture....
[IMG]local://upfiles/19071/662EB1D0A41342D5BCB6CADD54FA32A1.jpg[/IMG]
Yep, it should look like this when it's hooked up. It really won't matter how it is routed just so that the wire is long enough to reach the fuel gauge.
Old Feb 2, 2006 | 07:03 PM
67t5ponycoupe
The wire routing is as follows. It comes from under the dash and runs down the drivers side rocker panel under the sill plate. It then goes under the rear quarter window and up over the rear wheel well, all on the drivers side. It then crosses the trunk, inside the trunk, just foward of the gas tank. there is a hole in the trunk on the passengers side foward of the trunk the wire passes through that hole and then is routed back to the center of the tank, under the car to be hooked up to the sending unit. On the wire there should be a grommet that seals the hole that penatrates the trunk floor. Hope this helps.
StalkerGT
Sep 25, 2015 02:41 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
