i need a bolt
Old Feb 2, 2006 | 09:25 PM
mlitz's Avatar
mlitz
Default i need a bolt
i am replacing my old rubber bushings in my leaf springs with some polyurethane one and i had to cut the bolt off (the one near the front of the car) now i need some new ones were can i get some.
Old Feb 2, 2006 | 09:43 PM
dcohen's Avatar
dcohen
Default RE: i need a bolt
a bolt and supply store
Old Feb 2, 2006 | 10:08 PM
Soaring's Avatar
Soaring
I ♥ Acer
My new leaf springs came with new bolts, but you can get hardened steel bolts at most hardware stores.
Old Feb 3, 2006 | 12:52 AM
67t5ponycoupe's Avatar
67t5ponycoupe
Been through this before. I looked and could not find them at the hardware store. They didn't have any long enough. had to go with mustang depot. They were the only onesI could find that had them. Look at this. http://www.mustangdepot.com/OnLineCa...shing_sets.htm
the 68 -73 is shorter so you might could find those. 65-67 are between 6 and 7 inches. The correct bolt also has a tapper on the end to make it easier to find the hole on the other side. Don't go to home depot and get some crappy soft bolt. These are hardened to grade 5 I'm pretty sure. They might be harder.
Old Feb 3, 2006 | 02:11 PM
gizahuna's Avatar
gizahuna
You can always try places online like Mustangs Unlimited or American Pony Parts. They usually have complete kits or just miscellaneous nuts and bolts. Good Luck
Old Feb 3, 2006 | 03:44 PM
mlitz's Avatar
mlitz
even though the bolt might say its grade 5 it is more like 10 and yes they have grade 10 bolts but you cant buy them and hardware stores.... who would need a grade 10 bolt. a saws all didn't even touch that bolt with out smoothing the teeth out
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
2poor4u2
Sep 26, 2015 11:08 AM
maestro1024
Sep 21, 2015 02:40 PM
