convertible mis aligned
Old Jan 20, 2009 | 01:23 PM
hdpearson13's Avatar
hdpearson13
Default convertible mis aligned
does anyone no why the convertible topseem to be misaligned.
thanks alot its a 94 gt
Old Jan 26, 2009 | 11:32 AM
yial's Avatar
yial
Did it get hit/ sat on/ have another heavy force or blow applied to it?
Old Jan 27, 2009 | 02:12 PM
hdpearson13
not that i know of the more i play with it seems the top cover is to tight and causing the one side to not go to finallooking position is this common
Old Jan 28, 2009 | 12:09 PM
03svtcobra12's Avatar
03svtcobra12
sounds like the top isnt on right, i have no idea how to fix it though
Old Jan 29, 2009 | 11:39 AM
hdpearson13
i am hoping thats all it is are you able to take them off and put them back on
Old Jan 29, 2009 | 08:01 PM
scan1959's Avatar
scan1959
I am a convertible top guy.
Usually if a top becomes misaligned after it was correctly aligned, a top tech would look at the hinges(the joints which fold like your elbow when the top goes up and down) and see if one of the hinge pins is coming out or missing.
Don't try to take the top off and reinstall it. Not fun!
Old Jan 30, 2009 | 10:25 PM
crusin92red5.0's Avatar
crusin92red5.0
When i put my top down all the way, one side sits higher than the other.
Old Jan 31, 2009 | 06:23 PM
hdpearson13
scan thanks ill check that out I thought I went through maybe I missed someting. I dont know if it was put on right or ever alighned. Is it hard to install new top
Old Jan 31, 2009 | 06:42 PM
crusin92red5.0
I've heard its not that hard to install one, if you buy the tops with the installation kit/video. but if its your only car, i wouldn't do it cuz it might take a few days and a few beers and some stress
Old Feb 1, 2009 | 06:15 PM
scan1959's Avatar
scan1959
hd, crusin92 is right. The replacement isn't rocket science. The frustrating part is, after stapling the new top onto the rear bar and then bolting it into place, finding that you stapled too much top, or not enough and then taking it all apart several times until you guess right. We have a few tricks up our sleeve, but still can't do a 'Stang in the labor time always that the book says it should take.
I think something has changed on your top. It could be in the front clamp(the ones that hook down the top to the windshield), hydraulic cylinder(it's not uncommon for them to start leaking or break at the mounting brackets), or maybe like I said the hinge pins(this is very common).
Keep in mind also, very few convertibles always are in perfect alignment. Even brand new. They frequently are slightly mis aligned.
lincolnshibuya
Jul 5, 2020 03:05 AM
jerrytubes
Oct 23, 2015 12:11 PM
winner99
Sep 30, 2015 07:04 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
