Overspray
Old Sep 21, 2010 | 06:43 PM
invisableflames's Avatar
invisableflames
Default Overspray
What is the best way to remove a good amount of overspray from my car? I painted my cage outdoors and the clear decided to go into the garage and completely cover the car. You cannot really tell it is there unless you feel the finish, or look closely but i want it gone. I first tried a clay bar and it didn't do a thing, barely slides across the finish at all. Next i started using the porter cable and a heavy cut polish and heavy pad. This works to some extent with LOTS of time. It takes forever! It has been three days and i maybe have 1/4 the overspray removed. Does anyone know any tricks for getting this stuff off?
Old Sep 22, 2010 | 12:13 AM
19stang88's Avatar
19stang88
sounds like your best solution is wet sanding.
Old Sep 22, 2010 | 07:19 AM
lizzyfan's Avatar
lizzyfan
Underboss
I did it with a clay bar believe it or not
Old Sep 23, 2010 | 12:02 AM
19stang88's Avatar
19stang88
he said he already tried to clay bar
Old Sep 23, 2010 | 09:10 AM
incorrigible's Avatar
incorrigible
Claying should be the best option to remove overspray. Were you using enough lube? If you are using plenty of lube and the clay is barely sliding across the paint, it's most likely very heavy overspray that is prventing the clay from sliding.
Keep trying using a medium grade clay with plenty of lube on a 2X2 section and see if that works. It should.
Old Sep 23, 2010 | 12:48 PM
invisableflames
I am using Maguires products but i think it is for light use. I will have to look into a better clay.
Old Sep 23, 2010 | 04:23 PM
lizzyfan's Avatar
lizzyfan
Underboss
But I knew it was retail clay
Yep^^
Old Sep 24, 2010 | 02:27 AM
stealth32's Avatar
stealth32
Have your tried using paint reducer or paint thinner I used to use it at a body shop I worked at and it works as long as its not new paint
MlissaG
Dec 15, 2007 07:23 PM
raubt
Sep 19, 2007 10:59 PM
Lanny
Aug 29, 2007 08:56 AM
mechanick858
Jul 16, 2007 11:41 AM
SVTBill
Feb 16, 2007 01:44 PM
