brake pads. cheapy? ceramic? differences?
Old Mar 10, 2006 | 06:25 PM
tictac's Avatar
tictac
Default brake pads. cheapy? ceramic? differences?
sorry. im a newbie in the mechanical world. im getting to the point where i need to change pads on my car. what is the diff between ceramic ($40/set) vs cheapy ($16/set)? i have no twin turbos or anything and i do a mix of highway/city driving back and forth to the installation where i work. is there a big diff? if not, ill prolly get the cheapy ones because, well, i need the money for other things such as udp and gears.
thanks
Old Mar 10, 2006 | 10:02 PM
1FUN5.0's Avatar
1FUN5.0
Default RE: brake pads. cheapy? ceramic? differences?
Big difference. Cheapies are just that. Ceramics have less noise, less dust and stop better. Will last longer too! Spend the extra money!!!
Old Mar 10, 2006 | 10:12 PM
bret's Avatar
bret
check to see whats on there now or call napa they will tell you exactly whats on there
Old Mar 10, 2006 | 10:45 PM
tictac's Avatar
tictac
hmm. alright. good to know. thanks
Old Mar 11, 2006 | 01:41 AM
kartracer55's Avatar
kartracer55
Raybestous makes brakes called "QS" for Quiet stop which are ceramic and produce virtually no dust. NEVER screw with or get cheap ith brakes... if you wanan go fast and be wreckless you need to make damn sure you can stop!
Jim
Old Mar 11, 2006 | 03:16 AM
03YellowPony's Avatar
03YellowPony
NEVER go with RayWorstos...I've sold all diferent kind, I've installed just about every brand...RayWorstos are the HARSHEST pads you can buy. They will prematurely wear out your rotors! Hawke's are pretty damn good. Ceramics are pretty damn good also.
Old Mar 11, 2006 | 09:19 AM
TBird232ci's Avatar
TBird232ci
Ive used those 16 dollar brake pads before when i had nearly no money. It was either good brake pads, or gas.
Those were horrible, my wheels were already hard to clean, and those pads made it so much worse. I almost gave up on keeping those things clean.
Old Mar 11, 2006 | 01:23 PM
Tim37's Avatar
Tim37
i like wagner thermo quiets they usualy run about 40 bucks a set but they are life time warrentied agiast noise and wear (you wear them out go back and get another set free) and a plus is they have reduced breakdust and wear. i had a set on my avenger, those cars are known for wearing front breaks i did my first front break job at 18k miles with a worn out set of front breaks i sold the car with 72k mile and still had a lot of pad left.
mtgldr
Feb 3, 2024 09:00 PM
Tivo304
Aug 28, 2023 12:19 PM
LivingInThePast
Sep 16, 2015 12:20 PM
DoctorScary
Sep 9, 2015 07:53 AM
Sep 8, 2015 11:50 AM
