Sponsored by:
Sponsored by: DashLynx
No fill plug on diff?
Old 03-26-2006, 02:47 PM
DJ19895.0
DJ19895.0's Avatar
Default No fill plug on diff?
I have got my mustang on jackstands about to change the diff fluid when i notice before i start anything that there is no fill plug?? It has a 93 cobra rear end on it if it makes any difference. So how do i fill it back up when i,m done? O and another question how much fluid needs to go back in? Thanks!!
DJ19895.0 is offline
Old 03-26-2006, 06:04 PM
ShadowDrake
ShadowDrake's Avatar
Default RE: No fill plug on diff?
Do the 93 Cobras have a soild rear axle? If so, the fill plug is on the front of the differential, driver's side. Right near where the driveshaft goes in. A 1/2 inch drive ratchet (no socket) will work to get it out, the plug is REALLY shallow though, and I busted my hands quite a few times.
About two and a half quarts will go in to a standard Ford 8.8" rear... so buy three quarts.
ShadowDrake is offline
Old 03-26-2006, 06:36 PM
Mthd11
Mthd11's Avatar
i heard that u could put like a plastic bag filled with the oil then just run the car with the bag in the diff. i saw/heard this somewhere, so dont blame me if your diffy locks up, the bag would probably disintegrate (sp?) anyways. Someone confirm this lol
Mthd11 is offline
Old 03-26-2006, 06:38 PM
Smooth_J
Smooth_J's Avatar
ORIGINAL: Mthd11
I heard this too, but I have no idea if it works on not...
Smooth_J is offline
Old 03-26-2006, 07:29 PM
Mthd11
Mthd11's Avatar
k good, i now know that i will not anhiliate my 5.0 with stupid ideas. Someone should try this.
Mthd11 is offline
Old 03-26-2006, 07:59 PM
Chopper
Chopper's Avatar
That's how they lube the gearcases on locomotives.When they get low they throw in enough bags to fill it up.
It probably wouldn't hurt your car but since I've never seen it as a suggested technique I wouldn't even consider it.
Chopper is offline
Old 03-26-2006, 09:26 PM
03YellowPony
03YellowPony's Avatar
JESUS! Just get a pump setup from the local parts store. And if needed, you can put a piece of fuel line on it to reach the hole.
03YellowPony is offline
Old 03-26-2006, 11:13 PM
DJ19895.0
DJ19895.0's Avatar
Ok got it done, it was on the drivers side near the drive shaft, thanks for the replies.
BOB ROME
07-26-2023 01:54 PM
Dathan
10-05-2015 05:52 AM
breaking
10-02-2015 01:27 PM
GLOCKer
09-28-2015 07:36 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: No fill plug on diff?
