question about heads
Old Mar 13, 2004 | 12:57 PM
notch4u's Avatar
notch4u
Default question about heads
Ihave a 87, Iput a 85 motor in Iwas told to change the heads to 87 .MY questin is is there a difference between 85 & 87 &later heads?
Old Mar 13, 2004 | 09:47 PM
vfast's Avatar
vfast
I ♥ Acer
Default RE: question about heads
a lil bit but with those 85 pistons your opitons are limited....going to a longer rocker will help
Old Mar 13, 2004 | 11:56 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Not if you havent got a wild cam.
Your 85's have a heart shaped chamber and are all around just a poor performing head.
Your later E7TE's are a better flowing head and have much more going for them than your earlier E5's.I also belive (DONT HOLD ME TO IT) your E7TE's haVE 1.78/1.54 valves which arent much but better than what you have.Your E7TE's will bump your compression ratios up a bit as well.
For just bolting them on and doing nothing more (AND I HIGHLY SUGGEST YOU GET A VALVE JOB WHILE THEYRE OFF) you will notice a little extra power they really are a better head and with minor porting you can get them to impressively flow quite a bit.
Vrooom
Feb 21, 2016 05:25 PM
EASTIDEE123
Sep 14, 2015 03:52 PM
cbird1177711
Sep 2, 2015 08:51 PM
cbird1177711
Sep 2, 2015 04:12 PM
