Tune Up Time!
Old Mar 15, 2004 | 11:48 AM
Obsol3te's Avatar
Obsol3te
Default Tune Up Time!
When you do a Tune-up
what kind of Plugs, Caps, Filters etc do ya all get?
Any specific Brands you'll stick to for as long as you own a car?
Old Mar 15, 2004 | 11:53 AM
pichinco's Avatar
pichinco
Default RE: Tune Up Time!
Just did a tune-up, and did Autolite double plat plugs, and Autolite Professional wires. Probably stick with that brand until the end. There are several good reviews of oil filters, I don't know of something similar for fuel filters. I usually pick up whatever brand the store has.
Old Mar 15, 2004 | 01:36 PM
roundman's Avatar
roundman
Fram Sure Grip Oil filters, fuel filters, etc except for the K&N air filter which is reusable with a recharging kit. Autolite plugs work fine and are inexpensive. If money is no object, you might try the Splitfire plugs, I used a set of those and they seem to add just a little extra pep but $40 for a set of plugs is a little steep. Right now I'm running Accel U-groove short racing plugs to get extra clearance around my MAC equal length shorty headers as the spark plug wires are mighty close and I already burned up the #3 wire once! Ford Racing sells a nice set of plug wires that are made to fit and pre-labled for each plug, they're 8mm silicon if I remember correctly and a nice Ford blue in color. They look good with the matching blue high performance silicon radiator hoses. Summit Racing sells them for about $40 bucks.
Old Mar 15, 2004 | 07:29 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
MOTORCRAFT or MOBIL 1 oil filters,Fram sucks *** and have the poorest filtering capabilities.Autolite or motorcraft plugs,MOTORSPORT 9mm wires theyre numbered and come in yellow,blue,or red.As far as air filters i like paper myself.And as far as fuel filters i use motorcraft as well.
Old Mar 16, 2004 | 11:35 PM
04ShakinSteed's Avatar
04ShakinSteed
I ♥ Acer
Yes, FRAM is one of the worst oil filters you can buy.
Old Mar 17, 2004 | 05:46 PM
vfast's Avatar
vfast
I ♥ Acer
plug wires.....msd or holley new one very low ohms(this is why you buy them)......form 9mm suck ( I used alum. tape for #3 never gets burned)
plugs..autolite
dist cap anyone of them as long as it has brass turnimals
oil filter...hastings,amsoil,k/n,mobil1 these are the best
oil....amsoil,redline,mobil 1 these are the best
airfilter......k/n, accel, amsoil
fuel filter..good ole motorcraft
pcv valve (use a higher number) for clean engine
coil...msd or accel
drfister
May 3, 2018 10:38 PM
mirandaandjimmy
Nov 16, 2015 08:51 AM
YoungStangsMan
Sep 5, 2015 07:01 PM
Cin K
Aug 31, 2015 07:31 AM
timeformiller44
Aug 26, 2015 12:03 PM
