Water Pump is Weeping Like Crazy
Old Apr 22, 2004 | 07:18 PM
tj_gavin's Avatar
tj_gavin
Default Water Pump is Weeping Like Crazy
From previous posts, my '94 3.8L had been running a little hot with a fluctuating gage. Today I went to get in and there was a huge coolant spot on the ground. Inside, there was coolent comming out of the weep hole and the pulley below the pump was completely covered in burned coolant. Should I just consider my water pump dead and replace it?
Old Apr 22, 2004 | 07:31 PM
TheGmKiller331's Avatar
TheGmKiller331
I ♥ Acer
Default RE: Water Pump is Weeping Like Crazy
YES SIR!ITS DEAD
Get a new one and all is fixed.
Old Apr 22, 2004 | 08:53 PM
MelloYello's Avatar
MelloYello
Yup very much dead..... as soon as those baby's start leaking you have to buy a new one
Old Apr 22, 2004 | 10:32 PM
619socalstang's Avatar
619socalstang
the manufacture puts that hole there so you know when the pump goes out, mechanical fuel pumps hav ethe same thing.
Old Apr 22, 2004 | 10:55 PM
nhdungeonracer's Avatar
nhdungeonracer
Since you have to replace the water pump, might as well remove a few more bolts and replace the timing chain and gears. Better than having to do another teardown later.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
