Water pump quere
Old May 6, 2004 | 06:07 PM
Turtle's Avatar
Turtle
Default Water pump quere
Does anyone know the approx. H/P loss when using the OEM water pump for a 80's GT 5.0? Thanks.
Old May 6, 2004 | 06:20 PM
WNDSOR's Avatar
WNDSOR
Default RE: Water pump quere
um...i'd say 0
Old May 6, 2004 | 08:57 PM
MelloYello's Avatar
MelloYello
Well with an aftermarket pump you might gain a little but nothing noticeable, with an aftermarket pump things will run cooler.... There isn't a huge gain in hp switching from stock to aftermarket... Just mainly temp change.... So with the OEM your not lossing HP..
Old May 6, 2004 | 10:12 PM
NOS/MAN's Avatar
NOS/MAN
I ♥ Acer
youll over heat on the street...you better be doing this only..
[IMG]local://upfiles/5822/Us528622419.jpg[/IMG]
[IMG]local://upfiles/5822/Ie979419411.jpg[/IMG]
[IMG]local://upfiles/5822/Ej144665163.jpg[/IMG]
[IMG]local://upfiles/5822/Ng102857089.jpg[/IMG]
[IMG]local://upfiles/5822/Mx222141415.jpg[/IMG]
Old May 7, 2004 | 01:35 AM
VertStangGT86's Avatar
VertStangGT86
Unless you've got a full race engine or close to that I wouldn't worry about the stock one as long as it's working fine.
Old May 7, 2004 | 03:22 PM
roundman's Avatar
roundman
at high engine speeds, the water pump can use up about 15 HP from the engine. that's why a lot of racers switch over to an electric pump to get the most HP to the wheels at the track. it's also one reason for underdrive pulleys as they slow down the pump so it don't use up so much HP at higher speeds.
jwog666
Dec 27, 2021 08:09 PM
jerrytubes
Oct 23, 2015 12:11 PM
Bokeo
Oct 10, 2015 08:28 PM
b8checker
Oct 8, 2015 12:55 PM
b8checker
Sep 30, 2015 07:11 AM
