1st and 3rd gears grind and pop out.
Old 10-08-2006, 11:57 PM
embanning
embanning's Avatar
Default 1st and 3rd gears grind and pop out.
I have a 1998 Mustang Gt which I just recently bought from a private dealer. It just rolled over to 100,000 miles when the transmission started acting up. Whenever I try to engage 1st gear it pops out immedietly. Also 3rd gear will grind every time i try to engage it aswell. 2nd, 4th, 5th, and reverse all work totally fine. I was wondering if the problem would be the syncros or anything related to that or do i have a more serious problem on my hands. Also I have 3.73 gears and a short shifter and i was wondering if these may be a factor to the problem aswell. Thanks.
embanning is offline
Old 10-09-2006, 01:38 AM
Tac2cul
Tac2cul's Avatar
Default RE: 1st and 3rd gears grind and pop out.
what short shifter?
Im not sure but your short shifter stops may need adjustments.....may look into that
also could be a bent shift fork or syncro's
id check the short shirfter stops and if u have the stock shifter install it and see how it goes...
Tac2cul is offline
Old 10-09-2006, 01:37 PM
Chopper
Chopper's Avatar
ORIGINAL: Tac2cul
what short shifter?
+1 The adjustable stops can work their way loose and cause this very kind of problem.
Chopper is offline
Old 10-09-2006, 05:50 PM
embanning
embanning's Avatar
It was the short shiffter, i replaced it with the stock one and it works like a charm, thanks a ton for the help.
Old 10-09-2006, 06:03 PM
kylebgt
kylebgt's Avatar
What brand ss is it? I will take it off your hands if you are planning on selling it.
kylebgt is offline
Old 10-09-2006, 06:41 PM
embanning
embanning's Avatar
It's a Roll-X shifter. Interested?? I would sell it cheap.
Nick Oliver
10-17-2018 04:22 AM
Sminemann
09-17-2015 09:24 AM
degner122
09-16-2015 07:09 AM
Blk Vert
09-09-2015 12:16 PM
raleigh05GTO
09-04-2015 07:09 AM
Quick Reply: 1st and 3rd gears grind and pop out.
