Best Brake Pad Suggestions
Old Oct 18, 2006 | 01:18 PM
KillSwitchNY's Avatar
KillSwitchNY
Default Best Brake Pad Suggestions
GUYS, i need help... i have front hawk's slotted rotors. now i need pads..
i want of course good stopping power and less brake dust and noise..
i was looking at steeda/hawk pads.... ebc greenstuff or redstuff.... im not sure what else to go with... please let me know whats out there that i should go with.... the car is a high power street car but everyday driving will be done. looking in the ballpark of $120 to spend... fronts only. thanks
Old Oct 19, 2006 | 12:04 AM
7arpad7's Avatar
7arpad7
Default RE: Best Brake Pad Suggestions
I have Hawk slotted rotors and pads... No problems or complaints... I am not sure that you can do all that much better without upgrading the whole breaking system.
Old Oct 19, 2006 | 09:40 AM
xzo6's Avatar
xzo6
If you do not like brakedust get Hawk ceramic pads.If you want something less expensive go with Hawk HP pads.There will be a bit of brakedust with the HP pads.Good value,however.
Old Oct 19, 2006 | 12:06 PM
sandcracker21's Avatar
sandcracker21
what rotors are you running with the hawk pads?
Old Oct 20, 2006 | 03:13 AM
KillSwitchNY
Hawk's slotted and vented rotors (5lug)
Old Oct 20, 2006 | 03:26 AM
KillSwitchNY
where can i get the ceramic pads??? im looking on summit and i found the hawk HPS pads that are like $70 but the ceramic pads are showing up only for like the newer cars
Old Oct 20, 2006 | 09:26 AM
live4motocross11's Avatar
live4motocross11
do you have to replace those rotors every pad change then, cuz u cant turn drilled and slotted rotors can u? i.e. on the brake lathe
Old Oct 22, 2006 | 07:04 PM
live4motocross11
ne one
Old Oct 23, 2006 | 02:33 AM
Colorado_Mustang's Avatar
Colorado_Mustang
I would assume that slotted/drilled rotors can be machined...they had to be machined during the manufacture process.
Old Oct 27, 2006 | 04:42 AM
KillSwitchNY
ORIGINAL: live4motocross11
nah you have to be able to cut drilled rotors.... theres no big difference. but i only got the slotted ones anyway because im not about to have my rotors crack at the holes!!. although i do like the design of the drilled/ slotted rotors where the drills are separated enough to reduce cracking.
Ghost_Conscience
Sep 23, 2015 02:17 PM
67LimeCoupe
Sep 21, 2015 06:34 PM
LivingInThePast
Sep 16, 2015 12:20 PM
