tranny causing stalling?
Old Nov 28, 2006 | 05:40 PM
7upedition's Avatar
7upedition
Default tranny causing stalling?
Guys,
Automatic transmission when shifted is causing the car to almost stall out,when in gear runs strong as usual, between gears or changing gears the motor nearly dies. What would cause this? The car is at a complete standstill when this happens, I'm at a loss...
Old Nov 28, 2006 | 06:28 PM
Archion's Avatar
Archion
Default RE: tranny causing stalling?
Something sticking in the valvebody maybe, causing it to act like its in two gears at once, possibly even partially engaging reverse, very rare, but I have seen it happen, just not on a Ford yet, more prevelent on GM's
Old Nov 28, 2006 | 09:36 PM
7upedition's Avatar
7upedition
thanks, it on the wifes '02 Ford Explorer, I'm gonna get the tranny flushed and filled and hope that alleviates any stress on the valve body... hope it works... ahhhh
Old Nov 28, 2006 | 09:56 PM
Colorado_Mustang's Avatar
Colorado_Mustang
The tranny solenoid packs are known to be weak in these trannies. I'm 90% certain for that year...basically, if you don't have a dipstick, you have the problematic tranny. Otherwise, a flush and fill may be the cure. While you're under there, consider an external filter to really help the tranny live longer, as well as synthetic fluid like Amsoil.
ORIGINAL: 7upedition
Old Nov 28, 2006 | 10:10 PM
Archion's Avatar
Archion
Also look up a product called lube guard, it is some magical stuff.
Old Nov 29, 2006 | 09:21 AM
7upedition's Avatar
7upedition
Archion, Colorado, thanks I am definitely getting it refilled with pure synthetic fluid, and I'm gonna look into that additive also. Thanks Guys! I'll have to check on the dipstick.. can't remember, this is the first problem we've had with it.
Stone629
The Racers Bench
66
Jun 2, 2016 09:52 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
2poor4u2
Sep 26, 2015 11:08 AM
