331 stroker
Old Dec 18, 2006 | 05:46 PM
phil k's Avatar
phil k
Default 331 stroker
Hi there all.
I'm new to this forum as i'm from london, england, but i'm sure i'll be using it a lot in the future.
Anyway my question is this. how easy is it to fit a 331 stroker kit into a 302 block. how much (if any) of the block needs notching for clearance.
any advise on this subject would be great and very helpful.
cheers to all, Phil
Old Dec 19, 2006 | 02:02 AM
Colorado_Mustang's Avatar
Colorado_Mustang
Default RE: 331 stroker
331 requires nothing special (aside from paying attention to the compression ratio). 347 is a different story, and does vary block to block.
Old Dec 19, 2006 | 07:33 AM
phil k's Avatar
phil k
thanks for the reply. much appreciated.
cheers, phil
Old Jul 26, 2023 | 02:16 PM
Nickdaqwik's Avatar
Nickdaqwik
Uhh well the 302 to 331 conversion is simply bigger bores, so new pistons, longer stroke, which means new connecting rods and crankshaft, and all related hardware, bearings, rings machining of the block, yada yada yada. As far as notching the block or whatever, all the machine work is basically on the inside of the block, so it'll drop right in as the physical size of the short block hasn't changed. If you want a good recommendation check out Creb Engines on Ebay killer prices and their machine work goes above and beyond.
Old Jul 26, 2023 | 02:18 PM
Nickdaqwik's Avatar
Nickdaqwik
Default 331 Stroker question.
Old Aug 15, 2023 | 12:57 PM
Mark O'Neal's Avatar
Mark O'Neal
This is it for the 347.
justinm
Feb 17, 2009 11:53 AM
mstngsule68
Oct 5, 2008 03:06 PM
GaryBisiniere
Nov 14, 2007 04:14 PM
great 8
Apr 14, 2007 08:07 PM
RedRyder95
Jun 16, 2005 04:05 PM
