94 GT Won't Start
Old Sep 14, 2004 | 11:46 PM
94SVTDRVR's Avatar
94SVTDRVR
Default 94 GT Won't Start
I've got a 94 GT that won't start. It cranks but doesn't start. I've replaced fuel regulator modules, plugs, wires, distributor,etc. Got spark and fuel at the cylinders but still won't start. Anyone have any advice on what else to try?
Old Sep 15, 2004 | 04:10 AM
e40water's Avatar
e40water
Default RE: 94 GT Won't Start
How about youre timing? You may have youre timing chain broken, I would test the fuel pump as well. You may not have enough psi to youre injectors.
Old Sep 15, 2004 | 11:31 AM
Chopper's Avatar
Chopper
Does the engine even try to start?What about backfires?Even if it's jumped time it will still backfire,sometimes spectacularly!!!If the engine has jumped time,you probably have bent valves.Can you hear compressed air escaping out the intake or exhaust while cranking the engine.Does it turn over smoothly or does it sound like some cyls are making more compression than others?Good luck,keep us posted.
Nurdyguy
Jan 20, 2025 04:38 PM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
MusicCity615
Sep 12, 2015 07:05 AM
5.0 kevo
Sep 3, 2015 06:24 PM
