Back spacing on wheels
Old Nov 22, 2004 | 10:19 AM
chriscindy6369's Avatar
chriscindy6369
Default Back spacing on wheels
I have a 94 gt I'm looking to buy some welds for it. I want 15 3 1/2 in front or 15/4 in front and 15/8 in rear. Does anyone know what back spacing i need?
Old Nov 28, 2004 | 09:07 PM
chriscindy6369
Default RE: Back spacing on wheels
I'm guessing no one in here has my style Body with welds?
Old Nov 28, 2004 | 10:54 PM
dc_mann8's Avatar
dc_mann8
ive never seen ur style with welds before...
Old Dec 12, 2004 | 01:25 PM
roundman's Avatar
roundman
best way to find out is remove one of the rear wheels and measure the backspacing using a straight edge laid across the rim and measure down from this to the back of the wheel at the lugs. this will tell you the stock backspacing and if you stay with this, the wheels will fit OK. I wouldn't go with those real skinny wheels up front unless I was taking the car off the street full time as they will greatly reduce the front tires contact area and have bad effects on steering and braking on the street too. also be sure if you're keeping it on the street that you get wheels which are DOT legal, lots of racing wheels are not DOT legal as they are built light and not made for the big shock loads you encounter on the street like potholes and speed bumps.
Old Dec 12, 2004 | 04:59 PM
chriscindy6369
Ok roundman i'm thinking of just having the tires on for Weekends and at the track. I want to add a cage and everything needed to make it legal at the track. I'm told to go with a 15/8 rear with 5.5 backspacing. But i wanted to double check with what other people might have.
Old Dec 13, 2004 | 11:46 AM
roundman's Avatar
roundman
Based on what you have already run, you will need a roll bar at a minimum until you go qucker than 10.99, then you will need a cage. you will also need a driveshaft safety loop, and positive axle retention devices (C-clip eliminators) assuming you are running slicks. and when you get the bar/cage, it would be wise to install some subframe connectors also if you don't already have them.
drfister
May 3, 2018 10:38 PM
cyclop5
Oct 3, 2015 09:21 PM
gus_vb
Aug 29, 2015 11:35 PM
ponyride00
Aug 12, 2015 01:57 PM
ccwebb
Aug 11, 2015 06:47 PM
