will not start
Old Dec 8, 2004 | 12:46 AM
lucillesdaddy's Avatar
lucillesdaddy
Default will not start
92 gt 5.0 wont start new bat 3/04 new alt 11/03
wont turn over does not catch????? Just started since it got cold, charged the bat this weekend and tonight will not turn over getting pissed....any suggestions
Old Dec 8, 2004 | 05:26 AM
stangcrazy's Avatar
stangcrazy
Default RE: will not start
try your control module
Old Dec 8, 2004 | 12:50 PM
roundman's Avatar
roundman
put the battery on a slow charge overnight and then get a battery post terminal cleaning brush and take the cables loose and clean both the posts and cables real good with the brush and reinstall them good and tight. if any of the cables are showing signs of corrosion on the outside at the connectors, replace it as this gets inside the cable and kills the current flow to the starter so bad it won't work too. check the postive cable connection to the starter solenoid on the driver's side fender and clean/tighten it here also. also check the ground cable connection on the block down by the oil filter to make sure it's good and tight and finally check the power cable connection on the starter itself to make sure it's clean and tight. with a fully charged battery and good cables and clean connections the starter should work.
Old Dec 8, 2004 | 03:25 PM
IownaMustangNow's Avatar
IownaMustangNow
so does it like even turn over or ne thing? like give a lil reerrr or sumthin?? maybe its the starter...n not the battery...and if its turnin over it could be sum electrical ****, thats what took my bonnevilles life :'( may she rest in piece
zsmart
Convertible Tech
Feb 29, 2016 08:33 AM
1TUFF302
Nov 5, 2015 04:02 PM
StalkerGT
Sep 25, 2015 02:41 PM
dalefrancis88
Sep 11, 2015 07:15 AM
5.0 kevo
Sep 3, 2015 06:24 PM
