94 GT wont start could really use some help
I have a 94 GT 5.0L, I pulled it out of the shop today and parked it. All of a sudden it immediately shut down. I tried to restart and nothing. I did pull a plug and believe that i have verified that i have no spark. I checked the voltage to the coil and seems to me like i do not have any voltage at the coil. So now im at a loss here. I have checked all the fuses? Car still turns over just fine. Anyone have any ideas what could have happened?
RE: 94 GT wont start could really use some help
perhaps your coil took a poop on you? Or maybe your wiring somewhere along the way got messed up. Check all the main wiring from battery all the way through to your coil.
Were you doing something to it in the shop?
Do you hear the fuel pump running when
you first turn on the key?
You can just put another plug on the end of a
wire and check for spark.
I was not doing anything to the car recently no changes. I did put a plug in the end of the plug wire, i see no spark at all. At this point i see no voltage at the coil at all. Although i do not here the fuel pump either, It has to have at least 10V at the coil with the key in the on position correct? Can i temporarilly put 12 volts to the positive side of the coil to test?
dalefrancis88
09-11-2015 07:15 AM
